Check Plan Limits & Usage in XemailCampaign
How do I check my plan, limits, and usage in XemailCampaign?
Overview
When running cold email campaigns, understanding your plan limits is critical to maintaining performance and avoiding interruptions. XemailCampaign provides a clear view of your plan, usage, and available resources so you can scale campaigns efficiently without exceeding limits.
Key factors such as how many leads you can upload, your sending volume, warmup capacity, templates, and connected sender accounts directly impact how your campaigns run. Keeping track of these ensures that your outreach remains consistent and optimized.
Why checking your limits is important
Cold email performance depends heavily on controlled sending and proper resource allocation. If you exceed limits such as sending volume or lead capacity, your campaigns may slow down or stop.
For example, if your sending volume is fully utilized, new emails won’t go out. Similarly, if your lead capacity is reached, you won’t be able to add more prospects. Monitoring these metrics helps you plan ahead, distribute campaigns better, and decide when to upgrade or add resources.
How to access your plan and billing details
To check your plan and limits, go to your XemailCampaign dashboard and navigate to the Settings section. Inside Settings, open the Billing tab.
Here you will see your current plan along with important details such as:
  • Your active plan (Free, Paid, or Custom)
  • Start date and end date of your billing cycle
  • Next billing date and renewal cycle
This section gives you a complete view of your subscription and timeline.
How to check your usage and limits
Within the Billing section, you will also find the Usage panel, which shows how much of your allocated resources you have used.
This includes:
  • Campaign sending volume (emails sent vs total limit)
  • Warmup volume usage
  • Number of leads uploaded vs allowed limit
  • Templates created and usage access
Each metric is displayed with a usage bar, helping you quickly understand how close you are to your limits.
Understanding what each limit means
Each limit plays a different role in your campaign performance.
Your lead limit defines how many contacts you can upload and manage. Your sending volume controls how many emails you can send within your plan. Warmup volume determines how much warmup activity you can run to maintain deliverability.
Templates define how many variations of messaging you can create, while sender account limits define how many email IDs you can connect for sending. Together, these shape your campaign scale and efficiency.
What if you are on a free trial?
If you are on a free plan or trial, you can still access the same Billing and Usage section to understand your limits.
You will be able to see:
  • What plan you are currently on
  • How much of your limits have already been used
  • How much capacity is remaining
This helps you evaluate how the platform works within your current usage and decide when to upgrade based on your campaign needs.
How to use this information effectively
Regularly reviewing your plan and usage helps you avoid unexpected pauses and ensures smoother campaign execution. It allows you to adjust your sending strategy, distribute leads properly, and maintain consistent outreach.
For example, if your lead usage is close to the limit, you can plan your next upload accordingly. If your sending volume is nearing capacity, you can either optimize sequences or consider scaling your plan.
Final note
Your plan limits are not just restrictions they are designed to help you maintain safe sending practices and better deliverability. By keeping track of your usage and understanding how each limit affects your campaigns, you can run more controlled, scalable, and effective outreach using XemailCampaign.
