Manual Mode vs AI Mode in XemailCampaign
Overview
XemailCampaign offers two powerful modes to run campaigns: Manual Mode and AI Mode. Both are designed to protect deliverability while maximizing replies, but they serve different levels of control, experience, and scale.
This article explains how each mode works, when to use them, and best practices for switching between the two.
Manual Mode
What is Manual Mode?
Manual Mode gives you full control over every aspect of your email campaign. You decide what to send, when to send, and how to iterate based on performance.
Key Capabilities
  • Write and edit email copies manually
  • Create custom follow-up sequences
  • Set sending schedules and daily limits
  • Choose personalization variables
  • Pause, edit, or restart campaigns anytime
When to Use Manual Mode
Manual Mode is ideal if:
  • You already have proven email copies
  • You want tight control over brand voice
  • You’re running high-value or niche campaigns
  • You prefer hands-on optimization
Best Practices
  • Keep first-touch emails short and curiosity-driven
  • Change the angle in every follow-up
  • Monitor replies daily and refine copy weekly
  • Avoid increasing volume aggressively
Recommended for agencies, consultants, and advanced outbound teams.
AI Mode
What is AI Mode?
AI Mode automates campaign creation and optimization using XemailCampaign’s intelligence layer. It analyzes your ICP, industry, and responses to continuously improve results.
What AI Handles for You
  • Generates initial email sequences
  • Create a company persona with confidence score for your campaign
  • Set KPIs for you desired results
  • Adjusts sending patterns to protect deliverability
  • Learns from reply signals (positive, neutral, negative)
When to Use AI Mode
AI Mode works best if:
  • You want to launch campaigns quickly
  • You’re testing new ICPs or markets
  • You don’t have outbound copy expertise
  • You want scalable outbound without micromanagement
Best Practices
  • Provide clear ICP and offer inputs
  • Review AI-generated copy before launch
  • Let campaigns run long enough for learning
  • Avoid frequent manual overrides
Recommended for founders, lean teams, and fast-scaling outbound motions.
Switching Between Manual & AI Mode
You can switch modes at the workspace level.
Important notes:
  • Switching modes does not reset domain reputation
Info
You can switch from manual mode to AI mode, but only before you upload contacts. Once you begin working in manual mode with contacts uploaded, switching to AI mode requires contacting support.
Note: Once you switch to AI mode, you cannot return to manual mode.
