If your sender account is experiencing issues such as failed sending, sync errors, authentication problems, or unexpected inactivity, reconnecting the sender account is often the fastest way to resolve it.
In most cases, sender issues are caused by expired authentication, provider-level security changes, password updates, or disconnected SMTP/IMAP access. If the sender account is not paused but is still not functioning properly, you can safely remove and reconnect it.
Reconnecting ensures that the mailbox is refreshed with the latest credentials and settings.
You should reconnect a sender account if:
If the account is paused due to bounce rate or campaign limits, reconnecting is usually not required. In those cases, you should first resolve the reason for the pause.
1. Start by logging in to your XemailCampaign dashboard and going to the Email Accounts section.
2. Find the sender account that is having issues and select it. Once selected, remove or delete the sender account from your workspace.
3. Deleting the sender account removes the current connection but does not affect your campaigns, leads, or sequence content.
This step clears the old authentication and allows you to reconnect the mailbox from scratch.
After removing the sender account, go back to the Email Accounts section and click Add Sender Account.
Many sender issues happen because one of the original setup steps was skipped or changed later. For example:
Reconnecting from the beginning ensures the sender account is properly authenticated and ready to send again.
Once the sender account is reconnected, review its status in the Email Accounts section.
Make sure:
You can also send a small test batch before resuming full campaign activity.
